  1. Hopefully with some freeware/shareware program? If not freeware than what? I'm talking about if you have a couple seperate PSP Video 9-processed (or whatever) MPEG-4 files...what's the way to join them all together to create one big new MP4 file. Hopefully, that file would be the same quality and be the same size as the prior files added together...
    Can anybody help on this one?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    there might be a command line app to do this compiled by celtic_druid here http://www.rarewares.org/mp4.html
    Dec 2004
    Australia
    Latest cvs mp4box is supposed to support splitting, not sure about joining.
    If they are SP mp4's (as I understand it the PSP supports AVC and SP MPEG-4) then quicktime pro should be able to join them. Quicktime 7 when it is out should I guess be able to join AVC mp4's.
