I get "Canopus Procoder has encoutered the problem and it needs to close" while encoding DV AVI into MPEG2.
I had the Procoder working before, but I get this "Application Error" now, and I don't know what to do. I've tried to encode the same DV AVI over an over and it would fail in different spots (at the begiing, middle or end). I've tried different DV AVIs and the same thing.
I even reformatted my drive, loaded XP from scratch, tried Procoder before loading SP1, then after SP1, then after SP2, but I still get this error.
I've searched the web and different forums for this error but I could not find anything. Please Help!
dont use the dvd profile - use the standard mpeg profile and set the settings as dvd (select dvd first and then select standard iso mpeg, which will set most of the settings correctly) .. it is a bug , will be fixed in the service pack out any time now ..
also -- there are several builds of PC 2, make sure you are using the latest .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
it could be a codec problem. try to install the codec for that avi file.
and, maybe, there is a problem with your output file, you try to comvert intto something wrong. -
he said it was a DV file - so not a input codec issue
in terms of the codec anyway"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Canopus Procoder: chapters in DVD-export? How?
By Lippy Lipstick in forum Authoring (DVD)Replies: 4Last Post: 20th Dec 2008, 05:09 -
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 03:07 -
Encoding progressive NTSC material with Canopus Procoder 1.5?
By zee944 in forum Video ConversionReplies: 8Last Post: 13th Oct 2008, 07:56 -
Canopus Procoder Cropping
By spliffy in forum EditingReplies: 1Last Post: 20th Dec 2007, 21:25 -
Anybody tried Canopus ProCoder 3?
By cosmin in forum Video ConversionReplies: 1Last Post: 16th Oct 2007, 21:25
