hi peeps again still looking into conversion software and i'm now looking at this software can people share with me and others there points about this progy, good points and bad points, thank you.
Results 1 to 13 of 13
Good: You can't muck up any settings.
Bad: You can't muck up any settings, there are none.Cheers, Jim
My DVDLab Guides -
Good point is that this software can convert MANY different input formats (MPEG, AVI, etc.) that D.I.K.O. and The Film Machine can't handle. Also I am not sure if the other softwares can do this but this software lets you specify to force the conversion to NTSC or PAL.
Good things:
- converts AVI, DivX, Xvid, Nero Digital, MPEG...into DVD with chapters.
- very fast,
- very good quality video,
- if you demux the output DVD with VOBedit, you could directly import .m2v and .ac3 for DVD reauthoring,
- batch encoding (add several video files at once, and you'll get 1 DVD with several VOB's)
- perfect for unexperienced user
- freeware
Bad things:
depends who you are asking - for me, I do not want to find any.
No settings? Maybe I do not need 'em, for the purpose! -
It's quality isn't bad at low bitrates, although it can be a bit soft.
The biggest problem it has is that while it accurately calculates the correct target bitrate when it starts, it often doesn't come anywhere near it during the encode. I have had files caluclate out to 5700, but encode to 1700. There is a substantial difference here. It was consistent and able to hit it's calculated atrgets more often, I would be happier to use it. At present I still frameserve to CCE instead.Read my blog here.
Good: Blazingly Fast, Amazingly simple to use.
Bad: Won't let you use frame served AVS or dummy AVI files as input. If it would do that, I wouldn't use anything else. -
Well as far as I know it uses libavcodec and libavformat for at least input (not sure about encoding) so it only supports as input what they support as input. Fortunatly ffmpeg does support most stuff for input, although I wouldn't hold my breath waiting for windows only stuff like avs support.
Bad thing - if you have 23.976 source it will convert it to hardcoded 29.97 (no pulldown!) jerky motion.
Look like it is based on gui4ffmpeg (though the last one is more difficult to use, but has good help file and do not have probs with 23.976 streams I think).
Good thing - DVD is directly authored.
@celtic_druid QuEnc and FreeEnc are libavcodec based with avs support (though I think you know that already) -
Bad. But that's my view of all conversions that doesn't involve at least 4 different applications.
/Mats -
Oh yes they do. Handles video only, has issues if the input is i420 and not YV12, plus I think duplicates the last frame. But the support is there and has been since Feb with a patch available in Jan.
Also for piping I would suggest avs2yuv.
An app that views audio's frequency (Hz)?
By firebo14 in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2012, 19:34 -
Having trouble with views on Jubler 4.6.1.
By bahjan in forum SubtitleReplies: 0Last Post: 18th Aug 2011, 10:31 -
Win 7 sp1 update views
By johns0 in forum ComputerReplies: 8Last Post: 26th Feb 2011, 23:56 -
Anyone know how Windows folder VIEWS works?
By jyeh74 in forum Newbie / General discussionsReplies: 8Last Post: 26th Oct 2009, 11:52 -
Post counts and thread views
By Supreme2k in forum Off topicReplies: 3Last Post: 28th May 2009, 07:14
