Hello,
I've searched and read about some topics about this kind of problem and did as some answers suggested.
What I'm trying to do is to backup a movie, which is around 8Gb, but I end up with a small sized movie, around 2GB.
I ripped the movie with dvddecrypter "all files mode".
Started DVD Rebuilder (0.80) without any change at all, except "STEAL SPACE FROM EXTRAS : 50%".
The first attempt made with one click option and ended with a 2GB movie.
The second attempt, first I "PREPARED" the movie, then "ENCODE" and then "REBUILD". Ended up with a 2.1GB movie.
What am I doing wrong ?
Is this a normal behaviour ?
Hope someone can help.
Thx...
Results 1 to 10 of 10
Try this Thread at Doom9
http://forum.doom9.org/showthread.php?s=effe5868e97c55d1f66dc0f32ded5075&threadid=92083
or try using the installer found here"
http://forum.doom9.org/showthread.php?s=effe5868e97c55d1f66dc0f32ded5075&threadid=84487
Seems as if you have to have the correct file versions. Also the recommended method is to rip in iso mode in decrypter and then mount the image as a virtual drive for rebuild. -
OK...
I began from scratch, Installing AVISynth 2.55, then installed CCE Basic 2.69, an then installed DVD Rebuild 0.80 (with installer).
Instead of using 1 click mode, this time I used 3 click mode.
Same thing happened. From a 6GB movie, got a 2GB movie.
Playing thru PowerDVD, seems to be OK, sound and everything.
But was wondering if I could use the extra 2GB space, for some quality improvement... -
OK...
Haven't gone thru the whole movie, but from the 3 first chapters, it seems that half the chapter is missing on each one.
It is not processing the whole chapter. The audio goes on, but the movie freezes on a particular scene.
Even the subtitles are working perfect.
Seems to be cutting the chapters from the middle to the end, but the rest are intact.
The image, though, is very very good...
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
How to rip dvd into small size mkv
By mazeer in forum DVD RippingReplies: 5Last Post: 5th Jan 2011, 15:05 -
BD Rebuilder output files too small
By mpullar in forum Blu-ray RippingReplies: 9Last Post: 18th Mar 2010, 17:58 -
DVD Rip Final Size Differs
By brvignesh in forum DVD RippingReplies: 7Last Post: 10th May 2008, 10:40 -
Turn many small video DVDs to one standard size DVD
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 30th Mar 2008, 17:57
