This is a question for those who have use both TDA 1.6 and DVD-LAB. Why do you use one over the other. After I read some of the past posts I can pretty sum it up to these key points. If there is others plz mention it b/c that what I am after for.
TDA
PRO:ease of use
DVD-Lab
PRO:file format support
The thing that I am really after is the dvd menu. Does DVD-Lab does a better job than TDA?
Computer Spec:
winxp pro, 2.4ghz, 768mb ram, 100gb -
Cheers, Jim
My DVDLab Guides -
if you want advanced stuff
What I really want to do is like in the Notebook.
If any1 seen the notebook dvd they'd know exactly what i am talking about but anyway. When I click on a scene they 'd be bird flying right after I click it. That the type of menu I want to create. So is like
CLICK--->ACTION--->Play the sceneComputer Spec:
TDA errors
By siluet in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2009, 07:08 -
TMPGEnc DVD Author 3 (TDA) Questions
By Brent.M in forum Newbie / General discussionsReplies: 5Last Post: 10th Feb 2008, 23:34 -
TDA DVD Settings
By marioval in forum Authoring (DVD)Replies: 1Last Post: 28th Dec 2007, 06:08 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 18:04 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 09:40
