  1. I just got started in doing this stuff and have had success so far except that everytime I get the finished mpg file its always just over 700 megs. I followed the newbie guide and get like 732 MB files for each half. Thanks
  2. so what's the problem? roughly 796mb will fit on a 80min cdr unless you're converting to divx. one can only guess
  3. well on the cd-r it says 700 MB so i figured it would be too much, is the file size ok then?
    Feb 2001
    Kalmar, Sweden
    When burning VCD, SVCD and Audio CD you can fit 80 minutes (About 800 megs) on a 700 megs cd...
    That's about 740 megs VCD on a 650 megs cd...
    It's the audio length that decides the length/size of VCD SVCD and audio CDs
    Magnus Jensen
    A.K.A Geezus
