i have a lot of home camcorder movies on DVD...
...now that i have a PC, i wanted to try my hand at editing them using 'pinnacle studio9'...
..after a while without joy, i was told that i would need to 'convert' these DVD's before my editing software would recognise them...
i downloaded some software(ReJig, DVDdecrypter) & tried to follow a guide by a fellow named 'baldrick' on this site...
..i got 1 converted to MPEG?, and the 'pinnacle 9' recognised this, but there was >no sound<...
..the sound was, during the conversion process, put in a seperate AC3_audio file, which my editing software doesnt even see!..
my wish is for someone to make this problem go away, by telling me how to do this while keeping the sound & video together..
fanks..
...have i given enough info?
Can you import separate audio in pinnacle studio? Then convert the ac3 audio to wav with belight or goldwave.
If your audio is in a seperate file, you have to change your work area to timeline view and open the audio and drop it on the timeline seperately.
Pinnacle does not automatically import the audio with the video unless the audio is in the video file.
Pinnacle will import certain audio file extentions though, so make sure you check it out first. -
My advice is find something that will accept the video you already have. If there on a DVD and playable on a DVD player then you "should" be able to edit them with P9. If you have to transcode them to mpeg that will work in pinnacle you will lose quality, not much but you will. There's numerous trial version that you can try for compatibility, try Ulead Video Studio to start.
No, because what he said was....Originally Posted by northcat_8
So, I'm assuming that chuck.d has a DVD camcorder and now wishes to edit that footage.Originally Posted by chuck.d
I recommend Womble mpeg-video wizard to edit the vob's directly from the disk."Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by ZippyP.
um...yea....I missed the "camcorder movies on DVD" part...a few too many refreshments last night apparently
Noob Hi 8
By marcopolos in forum Capturing and VCRReplies: 13Last Post: 4th Feb 2012, 15:47 -
Noob Online
By cdanddvdpublisher in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2008, 13:25 -
What Mac for a noob?
By DereX888 in forum MacReplies: 30Last Post: 9th Dec 2007, 00:16 -
Help, I am a noob... What program for what I need?
By agent8 in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2007, 20:44 -
Noob VirtualDub help
By zamac_man in forum Capturing and VCRReplies: 7Last Post: 25th May 2007, 15:56
