Sorry for such a newbie question..but I am a newbie and this has been bugging me...
One movie is an 700 meg Xvid (avi) - when I use SVCD2DVD I get a good quality 4.3 gig DVD.
Now - if that same movie is in SVCD format, its now 1.5 gig, and made up of usually 2 bin files - I run through SVCD2DVD and it extracts the mpg files and creates my DVD for me - the resulting DVD is about 1.5 gig (pretty much the same size as the original SVCD)and the DVD quality is terrible.
So am I to conclude the 700 meg Xvid/avi makes a much nicer DVD than a 1.5 gig SVCD?
Thanks for any and all responses....
This is because the SVCD video files are left untouched except for audio conversion and inserting NAV packs. This is by design in the program. If you re-encode the SVCD file you are going to noticeably lose quality.
The XVID file is re-encoded to DVD (higher) bitrates and resolution and will (usually, depending on the original quality) look better than an SVCD.
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 15:18 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
Xvid to svcd + burn...
By Crapozo in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2007, 06:07
