  1. Banned
    Mar 2005
    new york
    does anyone know if an older I-MAC with OS 9 is compatible with a new Motorola wireless router. Motorola can't seem to help. I can get the router home page up by typing in the router address in the address bar in IE Explorer, the latest edition for MAC's, but can not get on the internet.
    Any ideas??
  2. Member Soopafresh's Avatar
    Jan 2004
    If you can get to the router, then the problem is between the router and your DSL/Cable Modem (whichever one you have)
  3. Banned
    Mar 2005
    new york
    thanks---i thought so!!!!
    Mar 2003
    get a linksys wireless ethernet bridge and it will allow your imac to work just fine with your router
    http://www.linksys.com/products/product.asp?grid=33&scid=36&prid=602
    edit
    I guess if you are hooking directly to your router then make sure your imac is set up for dchp in its network settings
  5. Banned
    Mar 2005
    new york
    well---it is working. netgear makes products that work with mac and IE 5.1.....i don't even own a mac---just doing this for a friend----anyone seen that MAC video?? it is sooo true!!!!!!
