Three little problems/questions:-
1) I have downloaded microsoft's net utility to allow me to install and test svcd2dvd, but I want to use it on my laptop, which isn't on the net. VCDHELP's download file for svcd2dvd is a .msi file. What should I do to install svcd2dvd on my laptop?
2) I have a slight audio problem.
If I input either an avi or a mpg (with audio - sterio or mono mp2 or pcm, 41khz or 48khz) file as an asset, svcd2dvd creates a mpg file of it, then transfers this to dvd. The mpg file that is created has audio, but the dvd has not, what am I doing wrong?
3) Are motion menus supported as well as static ones?
2: This should be sorted in RC8... Out later today or tomorrow. That said, does the DVD have audio when played back on the PC?
3: Not at the moment.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks CBC and ChrissyBoy, as soon as I get RC8, I'll register it, as, even without motion menus, it will be a very, very good program to use.
One last little question, assuming that RC8 is registered, what happens on future updates, are they automatically registered or do these need to be separately registered? -
They need to be seperately registered. Either online or using the license file which is created after the first registration. Either way your initial reg code is used unless your PC has changed in a major way (like OS reinstallation)
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
Svcd2dvd
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Apr 2010, 04:55 -
SVCD2DVD
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Feb 2009, 13:58 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 18:08 -
svcd2dvd
By tempac in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Mar 2008, 21:43
