I just got my NEC 3520A DVD writer from NewEgg, as so many here have, and placed it in my Firewire/USB-2 enclosure, which works with my old Plextor CD writer.
Well, after connecting everything up, it didn't power up!
So I fiddled with it a bit, and found that when I disconnected the enclosure's internal IDE cable, it powered up just fine. When I reconnected the IDE cable, it powered down.
I've never seen anything like this before! Does anybody know what may be causing this? There are no jumpers in the enclosure, and I tried CS, Master and Slave for the drive itself, but it made no difference.
This seems really bizarre...
- Tim
I might think of doing that, except that it works fine with the CD writer. I removed the new drive and put the old one back, and it works fine. So it's not the cable, but something having to do with the drive's IDE interface, I'd think... dunno. I wrote the people I bought the enclosure from, and NEC as well -- hopefully, some useful info will come my way. I suspect they'll say "send it back".
It's still possible it's the cable. There is what is known as a 40 conductor and 80 conductor cables. The latter is used for faster data transfer and may solve your problem. The 40 cables are a typically a heavier gauged cable vs. the 80 cable. Your HD(s) and/or internal optical drives may be using the 80 cable, you should be able to notice the difference between the two. Maybe you could remove one temporarily to try it with your enclosure to see if it solves your problem.
If a 80 conductor cable doesn't help, your enclosure chipset probably doesn't support DVD burners. -
What chipset is the enclosure? Take a look at this thread for some additional help: http://club.cdfreaks.com/showthread.php?t=119149
Hooray! The guy I bought the enclosure from suggested I upgrade the firmware and change some of the firmware configuration settings.
Unfortunately, the firmware upgrade utility couldn't see the damn enclosure.
However, when I tried it on a different computer, the upgrade utility saw it, so I upgraded, and right now I'm burning my first DL DVD on the drive.
Hooray!
Thanks for everyone's suggestions... it ended up being something as simple as firmware. Sure hope the drive wasn't damaged by bad pinouts, though, from the first time I hooked it up!
- Tim
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 11:52 -
Would you still buy an NEC ND-3520A today?
By Number Six in forum DVD & Blu-ray WritersReplies: 13Last Post: 20th Mar 2008, 08:24 -
Computer Won't Power On
By Sakuya in forum ComputerReplies: 8Last Post: 2nd Dec 2007, 01:24 -
Computer Monitor Won't Power Up
By StrengthFTW in forum Newbie / General discussionsReplies: 4Last Post: 24th Nov 2007, 11:08 -
NEC ND-3520A writes DVD's, which it cannot read
By Ruut in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 12:36
