hi,
I had converted AVI to MPeg using TMPGenc, then burn it to VCD using Nero.
But when i played it on the vcd player, the subtitles of the movie does not appeared fully, it only appear either half or 3/4. in short the subtitles cannot be seen properly.
What are the reason? what are the steps i need to take note either during encoding or burning in order to prevent such thing happen
thanks
search for overscan.
did you add the subtitles? then move them higher.
if it is permanent subs then add black borders. -
I think this question gets answered once a day, in average...
/Mats -
hi baldrick,
thanks for you reply.
acutally is permanent subs. sorry of my ignorant, what do you mean by "black borders"? how to add black borders?
So is nothing to do with the Nero?
thanks
colors out of alignment when re-encoding BD movie
By maca in forum Authoring (Blu-ray)Replies: 2Last Post: 10th Feb 2012, 19:45 -
colors out of alignment with bd rebuilder
By maca in forum Blu-ray RippingReplies: 2Last Post: 19th Dec 2011, 00:04 -
Correct cleaning/alignment for a Betamax?
By moxiecat in forum RestorationReplies: 16Last Post: 30th Sep 2010, 22:27 -
Check MP4's for GOP and alignment
By tb582 in forum Newbie / General discussionsReplies: 1Last Post: 16th Aug 2010, 11:18 -
spumux menus and buttons alignment
By begemotv2718 in forum Authoring (DVD)Replies: 1Last Post: 3rd Aug 2008, 09:31
