  1. Hi, all.
    I got the missing file - "wing32.dll" when I insert commercial VCDs. My VCDs use 'vcdplay' as an autoplay program.
    Someone suggested on the forum that it can be found in a \cdsample\demo\ on Win98 CD, but mine does not have such a subdirectory. Where can I find one? Thanks.
    Sep 2000
    Hong Kong
    The missing file - "wing32.dll" is installed in Windows 98 when you install the arcade demo. It can be found on the Windows 98 disk in the following path: cdsample\demos\rarc\ It is in a file called "arcade1.cab" Just extract it and copy to your windows\system\ directory. The player will work fine after this.
