I have been backing up DVD's for the past 6 months now, with no problems at all. But now I have come across this problem...
My drive reads & burns CD ok, & reads DVD's ok, but I get this just after I insert a DVD ready to burn. The DVD is not even 4GB, so I don't need a DVD9.
I'm using DVD Shrink 3.2 & have the 4.60 ASPI.
What do I do now???
1A23-0609-4030-2108-2159-6690
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 12:06:00 PM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 5:35:34 PM
Nero API version: 6.6.0.5
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <PIONEER DVD-RW DVR-108> Version: 1.18 - HA 0 TA 1 - 6.6.0.5
Adapter driver: <atapi> HA 0
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SP0802N atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-108 atapi Port 0 ID 1 DMA: On
DiskPeripheral : SAMSUNG SP4002H atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST CD-RW GCE-8320B atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-108 E: CDRom0
HL-DT-ST CD-RW GCE-8320B F: CDRom1
AutoRun : 0
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 622MB (637944kB)
Memory in use : 39 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
6.4.2005
NeroAPI
1:14:35 PM #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
1:14:35 PM #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
1:14:35 PM #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
1:14:35 PM #4 Text 0 File Reader.cpp, Line 127
Reader running
1:14:35 PM #5 Text 0 File Writer.cpp, Line 122
Writer PIONEER DVD-RW DVR-108 running
1:14:35 PM #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
1:14:35 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3286
First writeable address = 0 (0x00000000)
1:14:35 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3286
1:14:36 PM #9 Text 0 File Burncd.cpp, Line 3155
Turn on Disc-At-Once, using DVD media
1:15:16 PM #10 Text 0 File DlgWaitCD.cpp, Line 257
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1835417 (407:52.17, 3584MB)
1:15:16 PM #11 Text 0 File DlgWaitCD.cpp, Line 269
Write in overburning mode: NO
1:15:16 PM #12 Text 0 File DlgWaitCD.cpp, Line 2310
Recorder: PIONEER DVD-RW DVR-108, Media type: DVD-R
Disc Manufacturer: OPTODI - SCR016
Disc Application Code: 64, Disc Physical Code: 193
1:15:16 PM #13 Text 0 File DlgWaitCD.cpp, Line 431
>>> Protocol of DlgWaitCD activities: <<<
Compilation cannot be written on that medium type.
(Medium in drive: DVD-ROM. Medium required by compilation: DVD+R/RW, DVD-R/RW, DVD+R9 Double Layer.)
1:15:16 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 829
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1835568 (1835568) = #1835568/407:54.18
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1835568 blocks [PIONEER DVD-RW DVR-108]
1:15:16 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1042
Prepare recorder [PIONEER DVD-RW DVR-108] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3759243264, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1835568 | lead-out | 1 | 0x41 | 0x00
1:15:16 PM #16 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
1:15:16 PM #17 Text 0 File Burncd.cpp, Line 4042
Cache writing successful.
1:15:16 PM #18 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
1:15:16 PM #19 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 4x (5,540 KB/s)
1:15:16 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2604
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
1:15:17 PM #21 Text 0 File DVDR.cpp, Line 2260
Recording mode: Sequential Recording Mode
1:15:17 PM #22 Text 0 File Mmc.cpp, Line 21060
Set BUFE: Buffer underrun protection -> ON
1:15:17 PM #23 Text 0 File DVDR.cpp, Line 2401
Start write address at LBA 0
DVD high compatibility mode: Yes
1:15:17 PM #24 Text 0 File Cdrdrv.cpp, Line 8332
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
1:15:19 PM #25 Text 0 File Cdrdrv.cpp, Line 1284
13:15:19.046 - PIONEER DVD-RW DVR-108\H0 T1 : Queue again later
1:17:35 PM #26 SCSI -1064 File Cdrdrv.cpp, Line 1432
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x00D30000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x21
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x04 0x2F 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x21 0x02
1:17:35 PM #27 CDR -1064 File Writer.cpp, Line 311
Invalid block address
1:17:35 PM #28 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
1:17:35 PM #29 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
1:17:35 PM #30 Text 0 File DVDR.cpp, Line 2642
EndDAO: Last written address was 274175
1:17:35 PM #31 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 4x (5,540 KB/s)
1:17:35 PM #32 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
1:17:35 PM #33 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 12:06:00 PM
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28/10/2003 8:02:00 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Is this the first time this error occured or has it happened on numerous projects?
Google is your Friend -
get a newer version of nero,or burn slower.
LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
Pioneer DVR-520H video to PC using the DV-Out port - no disc burning.
By PuzZLeR in forum DVD & Blu-ray RecordersReplies: 14Last Post: 27th May 2021, 15:26 -
My Pioneer DVR-531H-s has developed burning problems ... replace burner?
By FulciLives in forum DVD & Blu-ray RecordersReplies: 86Last Post: 9th Dec 2009, 18:09 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
DVD-burning problems (Pioneer DVR-630H)
By tigrr in forum DVD & Blu-ray RecordersReplies: 7Last Post: 9th Jan 2008, 11:24 -
TYG03 burns at 18x in DVR-112D, only 4x in DVR-107D
By mikewillnot in forum MediaReplies: 1Last Post: 15th May 2007, 17:28
