once again I find myself resorting to the helpul people of this community (that I am SO glad I came across all those months ago).
My problem this time is not with authoring or changing formats (Well formats may play a role) - its more of a general question regarding thumbnails and windows.
When I go to the folder containing my files (when I open it) I find my computer freezes and then I get an error from DrWatson postmortem debugger. the error itself may or may not be important, and I could paste the error log if anyone would deem it necessary in order to help me out here, but before I do that, I should add that I had this problem in the past (before I had to reformat my computer due to an unrelated matter) and I am quite sure that the problem was solved when a certain codec was installed.
problem? dont recall the codec required. I am inclined towards believing it is the xvid codec, but ... I have the 1.1beta and.. no luck... SO... anyone out there have any similar problems? maybe a suggestion?
thanks in advance.
scratch the surface off a cynic - you will find a disillusioned idealist.
Codecs
By Nekias1 in forum Newbie / General discussionsReplies: 7Last Post: 10th Oct 2009, 13:00 -
Help using CODECS
By karthikaravind in forum Newbie / General discussionsReplies: 1Last Post: 15th Mar 2009, 03:06 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 14:39 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52
