    Apr 2005
    Africa
    I am looking for a program that can convert several AVIs to DVD. I am not concerened about the quality. I have a 3 or 4 AVIs that are about 45 minutes long, and I want to convert it to DVD but I want each AVI to be a seperate title. I would want this program to tell me what the bitrate would be and I would like to be able to use VBR encoding. I thought about putting it all into one very long AVI, aut I would lose the title points on DVD. I have also tired DVD2SVD but this prgram does not allow multiple AVIs and for some reason it does not make DVD ISO Image. I am running out on options, Need some feed back on this. Any Help is welcomed.
    bobajuba@hotmail.com
  2. Use Virtualdub to join the .avis, Then use this guide for dvd2svcd - make sure you install D2SRoBa plug in.http://club.cdfreaks.com/showthread.php?s=&threadid=61142
    When you select DVD Image in dvd2svcd - select Don't Make Images.
    After enoding use Tmpenc DVD Author to author your dvd. In "Chapter cut Edit" make new chapters where the original .avi's began.
    BTW, you can make iso images with dvd2svcd, I think you need DVD Decrypter
    Apr 2005
    Africa
    What about 3 AVIs with 3 different codec. And I am trying not to combine it into ONE big AVI. I would like to know the bitrate before hand.
    thanks again.
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Add the length (in time) of all AVIs.
    Use this sum in a bitrate calculator to get the (average) bitrate to use.
    Encode each AVI to DVD specs mpg according to this bitrate.
    Add each mpg as a separate title in "any" authoring app (TDA).
    Done.
    /Mats
  5. What i would do, is use TMPGEnc to encode the avi's to the correct mpg format (mpeg2). You can use the DVD template supplied with TMPGEnc.
    The use TMPGENC DVD Author to make your DVD, its pretty straight forward to use and you can put your videos on separate tracks and make your own menu etc.
