Did a few basic tests with 2 Plextor drives and some Taiyo Yudens I purchased from SuperMediaStore. Thought I'd try to briefly summarize with some very high level results regarding only visible burn rings and readability in the 2 Plextor drives:
Drives:
* Plextor PX-708A
* Plextor PX-716A (via an External Enclosure connected via USB 2.0)
Media Used:
* Taiyo Yuden DVD-R 4X (Code TYG01) - Purchased from SuperMediaStore and came in shrink wrapped Value Package
Results:
Burned the exaxt same source with the Latest version of Nero and found the following...
PX-708A
Burn Speed 2X: Burn appeared to be flawless in looking at the burn side (no visible rings) and is recognized easily by the PX708A when reading it.
Burn Speed 4X: Noticeable burn rings on the underneath side and the PX708A drive had extreme difficulty reading the disc after it was burned. Still plays fine on a DVD player though.
PX-716A
Burn Speed 4X and 8X: Both speeds here looked very good at the bottom of the disc and both Plextor drives quickly recognized the discs after the burn.
Summary:
With the PX-708A and using the Taiyo Yuden DVD-R 4X burning at 4X, the burn completed successfully although the drive that burned it could hardly read it and I noticed "burn rings" underneath. I have never experienced this with my Ritek DVD-R 4X discs. Hard to really tell how much of a problem this is though because all of my DVD players play it fine.
Not too much detailed info here however I may run some error checks with the Plextools software when I get the chance...
Results 1 to 1 of 1
A question about Taiyo Yuden.
By wtsinnc in forum MediaReplies: 18Last Post: 13th Jan 2013, 05:03 -
Bad Taiyo Yuden discs
By StrobeLightEpileptic in forum MediaReplies: 61Last Post: 2nd Jan 2010, 19:30 -
Taiyo Yuden DVD -- are these shiny?
By lordsmurf in forum MediaReplies: 10Last Post: 21st Jan 2009, 14:45 -
Taiyo Yuden ... an omen of problems to come?
By AlecWest in forum MediaReplies: 20Last Post: 17th Jan 2008, 10:27 -
Taiyo Yuden DVD-R - Thanks
By casual-dvduser in forum MediaReplies: 3Last Post: 6th Jun 2007, 03:59
