I have a 3 minute uncompressed AVI file that occupies lots of space on my hdd (2.6 GB) that I would like to compress, burn on a CD and remove with least quality loss.
(so in this case quality is more important for me than file size,cause it's a short music video not a movie)
How to make it to be exactly 700MB?
I've tried many different settings when trying to compress it with DivX,I choose highest quality and everything,constant bitrate etc,but the max size that I get is hundred and something megabytes.
How to preserve more quality but at the same time making it still possible to fit on a CD?
Which compression codec should I use? etc..
Thank you very much.
Why does it have to be exactly 700MB? If the compressed file at (100MB+) play ok and looks good, what's the problem? Nyah Levi
Use a bitrate calculator. https://www.videohelp.com/tools?tool=VideoHelp_Bitrate_calculator
What do you intend to play it on? If it's only a computer, just use MPEG-2 with a high bitrate or maybe Huffy if you want to keep it as an AVI with good quality. DIVX is not a good choice with what you have.
If you intend to use a settop player, you need to use a format like SVCD or DVD or CVD or possibly XVID to make it compliant with your player. Those formats have a maximum and minimum bitrate. Check the 'What is...' to the left for each format. -
Sounds like DivX achieved saturation at ~100MB's. You could try XviD at constant quant 1 with a high quality quant matrix. I don't think DivX uses quant 1's and it can only use MPEG or H.263 quants. Or as already suggested huffyuv or another lossless codec, with lossless audio it might bring it down to 700MB's.
Converting a dvd vob to a high quality compressed file.. for youtube.
By powrtoch in forum Video ConversionReplies: 3Last Post: 28th Nov 2009, 04:24 -
high quality VOB files
By nji899jus in forum Newbie / General discussionsReplies: 29Last Post: 15th Oct 2009, 08:32 -
Programs to Produce Very High Quality FLV Output Files
By devilcoelhodog in forum Video ConversionReplies: 2Last Post: 25th May 2009, 00:10 -
Low size, high quality WMV files
By devilfruit in forum Video ConversionReplies: 2Last Post: 29th Jan 2008, 17:08 -
High quality DVD and HD files, my recommendations
By ensign ricky in forum User guidesReplies: 0Last Post: 30th May 2007, 15:59
