I want to convert a DivX file with TMPGE 352 x 288, 25.00f/s. Would I have to load the ntsc film template? How much difference would it make if I loaded the regular ntsc template? Also what If the file has something like 20.00f/s? My griend just tried one and it only played 30 seconds or so and the quality sucked pretty bad. If you can help me please do. Thanks!
load the PAL template for this file:
Template for effect.
By tomofthefuture in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2011, 16:04 -
A simple, easy to use website template?
By sdsumike619 in forum ComputerReplies: 2Last Post: 23rd Apr 2008, 05:02 -
Adobe Encore - calendar template available?
By The Linguist in forum Authoring (DVD)Replies: 2Last Post: 2nd Jan 2008, 04:14 -
Printing Template
By mleb33 in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 08:09 -
Template selection in CCE...
By hiimbored in forum DVD RippingReplies: 5Last Post: 28th May 2007, 18:54
