I'm trying to backup a dvd with shrink. However, the dvd pops out whenever I press the "Backup!" button. Shrink then crashes whenever I insert the disc again to continue forcing me to rip it to the HD first. What can I do to fix this? I've used shrink before but this never happened.
Also, would it be better to run shrink on a computer with a fast cpu with a slow(4200 rpm) HD or a slower cpu with a faster HD?
Hmm... Have you tried playing the dvd for a few seconds before attempting to shrink? I've found that if you play for a few seconds with PowerDVD for example, before burning, it 'locks' onto the proper key for un-encrypting... only thing I can think of...
As for the faster/slower deal... Can you even burn a DVD from a 4200rpm drive? Maybe at 1X? But if you can, I'd think you should go with the faster CPU and slower HDD. Here's my thinking... if you're shrinking the disc, most of the time is spent on thinking, not reading from the disc. Even with a fast computer and hard drive, shrinking will still take an hour or so - meaning that it's bottle necked by the cpu not the HDD ('cuz it takes only a few minutes (maybe 10) to read an entire DVD's worth of information). Whether I shrink to or from either my 10,000RPM SCSI or a 7200RPM IDE, I get about the same duration (with Athlon XP 1600+). Just my thought.. anybody else have a differing opinion? -
There should be DVD files on your pc that was generated by shrink. Just load the VIDEO_TS folder files into your favorite DVD burner.
Quality is my policy. -
Originally Posted by Stormin Norman
I played the dvd with PowerDVD but the problem is still there.
Originally Posted by akrako1
dvdshrink
By Faerel in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2010, 23:07 -
dvdshrink for bluray
By xenotox in forum Blu-ray RippingReplies: 20Last Post: 18th Jul 2009, 09:10 -
Help wanted for DVDShrink 3.2
By _beavis_ in forum Newbie / General discussionsReplies: 13Last Post: 6th Feb 2009, 00:11 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 17:17
