I've disabled AutoRun on my DVD/CD drive because I hate being asked over and over the same question. Have I made a mistake?
Big Government is Big Business.. just without a product and at twice the price... after all if the opposite of pro is con then wouldn’t the opposite of progress be congress?
No, you will just need to open any CD/DVD manually from now on.
I have my system setup the same way. I can't stand to put an data cd in to get a few files off and the whole program tries to install. Or when you put a DVD in and it starts to play. Just my 2 cents worth. -
You can set up Autoplay so that it gives you a list of options of what to do, instead of playing directly.
For example, a dvd movie:
I prefer it this way rather than going into my computer, D: drive or open the preferred application.
Autorun Powerdvd in MCE2005
By alucard2050 in forum Software PlayingReplies: 0Last Post: 23rd Feb 2010, 19:30 -
Question about how antivirus stops autorun/exe on USB
By jimdagys in forum ComputerReplies: 5Last Post: 23rd Feb 2010, 17:19 -
Autorun Precedence - DVD & Autorun on the same disc
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2007, 20:26 -
How to make an autorun VCD in English please!
By jimiir in forum Authoring (VCD/SVCD)Replies: 10Last Post: 8th Aug 2007, 22:56 -
DivX on DVD Autorun Software
By Burgos in forum Software PlayingReplies: 0Last Post: 31st May 2007, 09:13
