Same problem here too. With Windows XP SP3, I am only able to convert (using the above guide) one VOB file at a time (batch encoding does not work). Additionally, when a VOB file is loaded, no properties show in the related window, so I have to guess at wich audio track to use. Any help with either problem would be appreciated. I posted a similar comment under the gui4ffmpegs tool section, but it seemed to have been "magically" deleted???
Originally Posted by StealthKing
Results 31 to 33 of 33
Ok, the problem is in the folder structure. After unpacking you'll have a folder named Gui4ffmpeg, gui4ffmpeg.exe and ffmepg.exe in the main folder. Open the folder Gui4ffmpeg and copy the whole content into the main folder.
Then the problems with property displaying and batch file handling are solved.The home of the sun - http://www.blueview.de.vu
divx 2pass encode error
By ledishis in forum Video ConversionReplies: 3Last Post: 4th Apr 2012, 15:47 -
Is it possible to encode divx files to larger than 5gb?
By yoda313 in forum Video ConversionReplies: 18Last Post: 4th Jul 2008, 12:25 -
Better format to encode to: MPEG2 or DivX/AVI?
By Grunberg in forum Video ConversionReplies: 15Last Post: 15th Feb 2008, 09:29 -
How to convert DIVX/XVID to DVD with gui4ffmpeg
By gui4ffmpeg in forum User guidesReplies: 41Last Post: 12th Nov 2007, 13:35 -
Trying to encode DVD to DIVX/AVI or h264
By cassavetes in forum ffmpegX general discussionReplies: 11Last Post: 25th Jun 2007, 11:46
