Results 1 to 9 of 9
  1. Member Richie V's Avatar
    Feb 2004
    Cardiff, Wales, UK.
    Hello,
    I'm looking for a program in which I can create my own sound effects. I'm tired of searching for royalty free effects online as they are often very low quality, so I would rather create my own.
    Could you please recommend me some programs to look into. At the moment I just want to try some trials/demos, so price isn't really an issue.
    I'm not being lazy I've already searched for programs like this, there are just so many out there. I thought it would save time if some of you kind folk could recommend the best ones.
    Thanks in advance.
  2. Member Soopafresh's Avatar
    Jan 2004
    Create your own, as in shaking a rice box in front of a mic ?
  3. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    Create your own, as in shaking a rice box in front of a mic?
    - That'd be one way. I've seen a video on how those guys recorded all those sound effects for Star Wars - they used a mic and a recorder. After recording what you can use as sound effect, you can try Sound Forge, Audition, Cakewalk (maybe?) to manipulte your files ...and there's another software - I don't remember its name, but it generates effects as synthesizers.
  4. Member Richie V's Avatar
    Feb 2004
    Cardiff, Wales, UK.
    I think I've found what I'm looking for: FL Studio 5. It's simply amazing.
  5. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    Really? Can you tell us a bit more about that? Thanks..
  6. Member Soopafresh's Avatar
    Jan 2004
    Fruity Loops ? That's a sequencer, like Acid.
  7. Member Richie V's Avatar
    Feb 2004
    Cardiff, Wales, UK.
    Heh, I guess I was a bit vague in describing what I wanted.
    I already record and manipulate foley effects using Adobe Audition. I wanted a piece of software in which I could digitally create sound effects and really tweek them to my preference. FL (Fruity Loops) Studio 5 lets me do this.
    EDIT:
    If anyone cares, here's what I've used it for. I'm still learning but I'm pleased with the outcome so far. Vision Often is the video shop where I work part time incase you're wondering.
  8. I love Soundforge. I've also recently gotten Audition, but I've barely used it. I also use the Native Instruments Waves bundle. It's a VST effects and mastering bundle that is capable of some absolutely mind bending effects. Also, I use alot of softsynths. There are some freeware softsynths out there, but I mainly use Reason (which is also a sequencer/rhythm composer/loop manipulator and ROMpler (a ROM sampler). There are two synths--analog and digital; two samplers, one is vastly superior to the other; a drum machine; several effects racks; a sequencer; vocoder; several things in one package.
