Hello, I have a problem on audio when I am converting dvd to vcd. I have read afterdawn's guide on dvd to vcd conversion. I followed all the instructions starting from smart ripper, dvd2avi and then tmpgenc. I used Nero to burn and I created a VCD. When I played the VCD on the computer it works fine and has sound and it is indeed nice to watch. My problem is this when I am using the VCD to a vcd player(not the cd player attached to the computer but a regular vcd player with television) the video works fine but there is no sound.
My question is how can i put sound to my newly created VCD in order for me to watch it in a regular vcd player? Thank you very much!
Hello, Mr. Krispy Kripper. Thanks for your advice. I don't know how to check if my audio meets my vcd player standard. But one thing I did is I played my vcd to different vcd players of my neighbors. My vcd works out succesfully on their players! Is this method enough in checking the compatibility of my vcd audio to my vcd player? Thank you!
If the disc is working on your pc and your neighbors standalone players, then I would say your player is either broken or doesn't support VCD.
Google is your Friend -
Probably, but not necessarily. The PC for sure is, and the neighbors might be, more tolerant, and accept a somehow off specs VCD.Originally Posted by Krispy Kritter
/Mats -
The audio is OK if you used a vcd template when encoding the mpeg with tmpgenc.Originally Posted by boksingero2005
If your player is not broken and it supports playing vcd's then the problem is most likley that your player is very picky about the vcd compliance.Originally Posted by boksingero2005
The best way to determine if the problem is caused by your player beeing very picky about the vcd compliance is to try a vcd that has been authored with philips videocd toolkit.
vcd4ever. -
Hello guys, thank you for all your replies. My vcd is alright. It's functioning well with other cd's. Upon your suggestions there is an improvement. There is already sound but only you have to literally put your ears on the speakers to be able to hear. Any suggestions on how can i make the sound of my vcd more louder. Thanks.
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
What's the best-easily working program to rip sound from vcd ?
By billyww in forum AudioReplies: 1Last Post: 20th Jan 2009, 07:30 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 21:21 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
