I was using MainConcept MPEG Converter, workign great then i got a new computer. Now when i convert an avi to DVD i haev no audio. I have looked at all my setting and they are all good. I have no clue what it could be. I have tried many different .avi's and none have audio. Please HELP ME
Results 1 to 10 of 10
First, make sure you are able to hear the audio when playing the orginal file before you transcode the video in M.C. Its sounds as if you have an audio decode problem and maybe not have the proper audio codec installed for M.C to decode it.
Hope this helps. -
the audio does work on the original .avi. Possible that could be the problem any ideas on what or where i could find what i need? Thanks
MSI K8N Neo 2 Platinum
AMD 64 3500
1 Gb Corsair 2-2-5-3
80GB HD -
I'm guessing you'll need the AC3 codec if your source is an avi from the net.
Download and install the AC3 codec - https://www.videohelp.com/tools?tool=AC3_Filter
If that does not help, download and install the Gordon Codec pack - http://www.doom9.org/index.html?/software2.htm
Please make sure you are able to play the file before transcoding anything.
Hope this helps. -
well i checked with GSpot and it says MP3 which could be a problem not sure if it can handle it. But i had a problem with more htne this oen i haevnt had one good .avi conversion since my new computer. the AC3 codec didnt work. so im onto the next the gordon codec pack...Any more suggestions please post
I know what the problem is. It has VBR MP3. I want to know how to extract it to wav using virtualdub. I cant seem to find a tutorial. Thanks
Use VirtualDubMod. Open the file. Goto Streams>Streams List. Select the Stream and click wav.
But, IMO a better way would be to Demux the MP3 audio first and then use BeSweet to convert to WAV.When I was born I was so shocked that I could'nt speak for 18 months. -
Even simpler: Load the AVI in Goldwave. Save. Done.
/Mats
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
Mainconcept Reference - 2ch audio
By ranosb in forum Video ConversionReplies: 2Last Post: 11th May 2009, 06:10 -
multichannel audio in MainConcept Reference
By lord25 in forum AudioReplies: 15Last Post: 2nd Apr 2009, 15:03 -
MainConcept products !? use it or not..
By Harviz in forum EditingReplies: 1Last Post: 1st Dec 2007, 20:14 -
Mainconcept encoding problem - Audio
By Mysteriouskk in forum Video ConversionReplies: 0Last Post: 25th Nov 2007, 09:25
