i made a dvd with mpg's (TV shows) on it and i want to get them off. how can i get them back onto my pc?
Results 1 to 10 of 10
If in doubt, Google it.
If they were just burned as data, then you can just copy and paste them wherever you want them. If they were burned in DVD format, then you will have to rip them as jimmalenko stated above.
Google is your Friend -
i used TMPGEnc DVD Author to make a dvd (VCD MPEG2) and i burned it to a dvdr. then i deleted the vcd MPEG 2's off my PC, but i need to get them back on the PC in the same format (VCD MPEG2)
what program do i need to get them back on my PC? -
You can use TMPG DVDauthor to copy them back to your hard drive. Use this guide: https://www.videohelp.com/forum/viewtopic.php?t=224833.
It doesn't matter who you vote for. The government always gets in. -
Since they don't contain a CSS "cracking" requirement, you can just drag-and-drop them to your harddrive, then demux them.Originally Posted by dblue
You don't have to "rip" them, but most of the rippers will demux the data you selected into separate M2V and audio files, so using a ripper is sound advice.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
VC-1 to Mpg-2 and MP4-AVC to Mpg-2
By Bruce Kuhn in forum DVD RippingReplies: 6Last Post: 10th Jan 2008, 17:06 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
