Results 1 to 17 of 17
    Feb 2005
    Is it possible to open a ripped DVD and watch it using this version of PowerDVD? It came with my dell when I bought it last summer and maybe I'm wrong but all I can figure out how to do with it is play actual DVD's that I have in my hard drive.
  2. Yes. Click on one of the icons on the bottom-right (i think it looks like an eject button) and click "open media files". That should do it.
    -Yar, matey!-
  3. I'm a Super Moderator johns0's Avatar
    canada
    For dvd files you choose open dvd files on hard drive and browse to the VIDEO_TS and open that.
    Feb 2005
    I dont have that option. The only options available on the tool bar thing is volume, exit, play,stop, skip, title menu, angle, subtitles, languages. And on the main menu there is resume movie, restart, title menu, eject, settings, help. Thats it. I dunno if the version dell gave me doesnt have the option to do anything else but play DVD's or if I'm just an idiot, but I cant find the option to play a DVD from the hard drive.
    canada
    Feb 2005
    I'm telling you...I dont have that... how do you take a screen shot? I will show you what mine looks like.
    canada
    Press Prt Scrn from your keyboard and then open paint/edit/paste.If you dont have that option then its a typical dell screw up for the consumer taking out certain options.
    Feb 2005
    There's what the taskbar of my program looks like. The four little buttons are "Title Menu", "Subtitles", "Language", "Angle". I dont think my version has the option to play things other than DVD's. I think Dell messed up.
    canada
    Cant see the picture,have to upload it again.
    Feb 2005
    Can't get the upload to work.
  11. I'm a Super Moderator johns0's Avatar
    canada
    The max file size is 150kb,make sure it is smaller.
  12. How about this:
    If not try Media Player Classic->File->Open File->search for VIDEO_TS folder and select the first .IFO file.
    Feb 2005
    my file was smaller 30 kb. I type
    w/o the "then" of course and no spaces
  14. Originally Posted by SEALs1230
    It should look like this:
    Feb 2005
    Now why am i having so much trouble with something as easy as posting a screen shot. Something is wrong with me
    Jan 2003
    California
    I can verify that some Dell computers come with a version of PowerDVD 5 that does NOT have the option to play DVD's from the hard drive. My Dell at work is that way. I have my own purchased copy of PowerDVD 5 at home and it DOES have that option.
    He's not crazy.
    Feb 2005
    Figures....leave it to Dell. Well thx for the help guys.
    Check out the Band...feel free to PM me with opinions: http://www.purevolume.com/beneathitall
