Hi all,
I would like to know if anyone had or have the same problem as me.
What I am experiencing, is that after I prepare the movie for rebuilding, (using 3 click process) I get an encoded segment with garbage in it.
The steps I took are described below :
Installed AVISynth 2.55, CCE SP Trial 2.70, and DVD Rebuilder 0.80.
After everything installed, opend up the movie to be processed, and clicked on PREPARE.
After the PREPARE phase is finished, withou any warnings or errors, i clicked on ENCODE.
It starts encoding OK, no warnings and no errors, but when I open the encoded segment in PowerDVD, the segment plays garbage (FBI Warning) or with purple and pink colors scattered aroud (Company Logo Introduction).
When I open the AVS file with Media Player, the segment plays OK, without any problem.
Any ideas of what could be happening ???
Thanks in advance...
Here too?
My oppinions may change, but not the fact that I am right!
www.rockassoftware.pt.vu
DAudioK => https://forum.videohelp.com/viewtopic.php?t=306886
DVD Rebuilder
http://dvd-rb.dvd2go.org
http://www.jdobbs.com -
OK...
Finally made it work...
Just rolled back DVD-RB version (0.79) with installer, and everything went fine.
Think was a problem with AVS file, but in the end, all is running smootly...
Wasn't a problem with the encoder after all...
Just posting to see if may help someone with the same problem.
Bye...
BD Rebuilder stops encoding
By pepegot1 in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Jun 2011, 11:01 -
Bd Rebuilder Failing on Encoding
By Westie69 in forum Blu-ray RippingReplies: 4Last Post: 31st Mar 2011, 03:52 -
Encoding problem with BD Rebuilder(Green Overlay)
By ninjaxryder in forum Blu-ray RippingReplies: 2Last Post: 30th May 2010, 00:31 -
bd Rebuilder vc-1 encoding extras aborted
By malevolo in forum Authoring (Blu-ray)Replies: 5Last Post: 27th Apr 2010, 22:46 -
problem with dvd rebuilder!
By jonkiller in forum DVD RippingReplies: 1Last Post: 2nd Aug 2007, 09:58
