  1. I compiled a dvd project of mine and now want to make a few small changes to the menu's. How would i go about doing this useing dvd lab pro?
    thanks
  2. Member daamon's Avatar
    Melbourne, Oz
    I don't know if you can do it using DVDLab Pro, but you might want to take a look at menuedit or DVDRemake.
    I've not used either, but have seen them suggested for similar jobs.
    Good luck...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    What changes do you want to make, and why didn't you save the project file from DVD Lab Pro before testing everything ?
    Read my blog here.
  4. DVD-lab PRO can import VTS directly (File-Attach VTS) . If the problems are for example menus, import the vts with your movie(s) as VTS2 and then create new menus in VTS1. Connect these menus through bridge object to the movie of the VTS2 and compile again.
