i have a CD disk with a video file on it that opens with Macromedia Projector, which I assume was made from Macromedia Director. I was wondering if there was some sort of conversion process to extract the video and audio, then placed on to a DVD for viewing on a standalone player. I have used this site before for information and have always found something using search, but this instance has stumped me and I can find no information for this type of conversion if at all possible. If anyone knows anyway of doing this, I would apprecitate the help. Thanks you.
Probably need to use some kind of screen capture app. Even exporting video in director doesn't work to well as it misses film loops and stuff like that.
alright thanks, i try looking for something that can capture the video some how. thanks for the idea.
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 20:28 -
Macromedia Flash In Addition to Cache/Cookie Clearing
By Soopafresh in forum ComputerReplies: 2Last Post: 3rd May 2009, 08:34 -
Proble with Macromedia Flash
By hzgg2 in forum Video Streaming DownloadingReplies: 3Last Post: 19th Nov 2008, 03:44 -
What.When) is DVD video (or mpeg video for DVD) pixel ratio 1:1 or 1:1.09
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 21st Mar 2008, 07:05 -
can faulty/bad dvd-video dvds make ripples/whitelines in video?
By wiak in forum MediaReplies: 3Last Post: 22nd Jul 2007, 12:08
