Just curious, when would you (and when would you not) use the option to "Reallocate VIDEO_TS Structure"? Thanks in advance.![]()
I'd leave it on all the time. First, if you have done some editing, it helps check that the content of the vob files matches the ifo files. Second as this helps to find any play back control issues, it may allow for a more "compliant" DVD burn.
If you get an "failed to reallocate" error (perhaps because of some dodgy ifo's) but you are fairly sure the DVD will work anyway, turn it off so you
don't have the trouble of using ifoedit to fix the problem.
I prefer dvddecryptor, but sometimes use IMG classic. -
I kept getting an error w/ ImgTool Classic, that's why I am using ImgTool Burn. Error complained about the mkisofs, but the .exe file was still in the folder and it had worked 3 times prior to throwing up that message. Then not the next 3 times. So I tried Burn and it has worked since. Though, I do prefer decrypter over nero and would like to get classic working again. I have deleted the classic v0.91.4 folder and re-downloaded, no difference?!?!
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
DVD Shrink to VOB,IFO, BUP and then IMGtool to ISO, bigger than 7GB
By opieandy in forum DVD RippingReplies: 3Last Post: 28th Sep 2007, 15:04 -
ImgTool Files Too Large
By opieandy in forum Authoring (DVD)Replies: 4Last Post: 27th Sep 2007, 21:08 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 20:46
