I just purchased a Regent DVD-1000 which is the same as the Lenoxx DVD-1000. As soon as I started to use it, I recognised how the volume and other things looked the same as the OFFA firmware on my Norcent 300 which is the hacked Sampo firmware - and as it turns out Sampo is owned by Regent.
Sampo is disappearing as a brand name, but the firmware which has proved to be spread all over a lot of other brands and I'm guessing the Regent DVD-1000 is probably one of them.
So does anyone know if Sampo made a top loading player or what possible Sampo firmware might be able to be loaded onto the Regent/Lenoxx DVD 1000?
Here's a link to what the player looks like:
http://www.ishop21.com.br/storecenter/ishop21/files/produto.aspx?id=8142
I've taken some screen shots:
http://community.webshots.com/album/313728093iJwAnd?68
it's $39 Canadian at Walmart.
It's not IDE. It's whatever the micro thin ribbon type is called.
Unfortunately I can't see the chipset - the board is covered with a metal shield and I don't have a dremmel. I guess I will have to get one then see what's in it. I've tried a few bios display codes but no luck.
Do you recognise the interface as any particular version of Sampo firmware?
How is this DVD player with playing all the formats? (DVD-R, SVCD, ....)
Thanks -
Just bought one and tested it, NTSC and PAL no problems
Plays everything I threw at it
DVDr, SVCD and VCD
I missed out on thoes cyberhome ones when they first came out with the good firmware but this one seems better and cheaper. $39 = Very Happy
new regent 1000A
By cardek17 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 2nd Aug 2007, 21:41
