Hiya guys,
I have a 14gig source file - how can i get this onto an 8.5 gig DVD ?
What app do i need to get maximum quality onto a DVD ?
I tried DVD author, but afetr it hits 9 gig, it complains file is too big - i was then going to dvd shrink it.
Shame dvd shrink cant accept .mpg files.
Whats my best option guys, without the need for much fiddling etc with bitrates
Many thanks for your help
You need to re-encode to a lowr bitrate to reduce the size appropriatley.
There are 10 kinds of people in this world. Those that understand binary... -
how long (minutes) is that 14gb .mpg file? and what type of audio does it have?
George -
GeorgeW - hello mate, well it has been converted from a Satellite .rec file to MPG - its Wrestlemania21 from last night.
So its just under 4 hrs, with MPEG2 (mpa) audio (i think, not AC3)
rejig seems to be doing ok, i can specify a maximum output size which is great - so ive told it to go to 8000mb so will be ok for a DVD8.5
agree?
im pretty new to encoding, but not to dvd authoring.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Rip Blu-ray Movie to fit on two dual layer discs
By craigmack55 in forum Blu-ray RippingReplies: 10Last Post: 9th Dec 2010, 23:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39
