i am using dvd2avi to convert audio from the movie magnolia, i have tried with both track 1 (6 chan) and track 2 (2 CHAN) and i ge the same error in windows media player, i am using 48-->44.1 on ultrahih, normalization on 97 and everything else is normal
try extracting the audio w/o normalization or down sampling and see if you get the same problem
I am not an expert, in fact I am not sure I fully understand the question... But I have had trouble with larger movies (Green Mile, The Last Emperor ...etc.)
I have had to figure out how many VCD or SVCD I will be making for the movie and divide the dvd2avi converting.
For some odd reason when I go try to convert a large movie all in one lump sum.. the audio file is too large.
So what I do is I convert with dvd2avi in 2 seperate folders using the same vobs. (Usually the first third of a long movie, and then the remainder...which can be cut in 2 later)
If Magnolia is a big movie... I bet your problem lies in the size of the audio file (I think win media and TMPGEnc have limits on audio size)
Does this help or did I just waste your time?? hehe
MuxMan : Buffer Underflow
By Bonie81 in forum Authoring (DVD)Replies: 3Last Post: 23rd Oct 2011, 15:38 -
YouTube Buffer Speed
By gooberguy in forum ComputerReplies: 4Last Post: 25th Feb 2010, 21:12 -
Buffer Device question:
By butt_crack in forum DVD RippingReplies: 1Last Post: 5th Feb 2010, 11:35 -
What is buffer size?
By dzsoul in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 09:04 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 23:51
