Hello all,
Please enlighten me. How do the overhead projectors compensate for Macrovision assuming S-Video or Composite (RCA) input from an AV Receiver? I did a forum search and Google search but did not find any answer.
Thanks.
Prasanna.
*** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
best bet is to buy a video stabiliser,to remove some of the macrovision strains.
i know someone who uses a sony dlp and dvd player,and with the stabiliser connected,the picture is far better than without,on macrovision protected dvdsLifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
Hello RottenFoxBreath,
I don't think a Video Stabilizer is required. I think that LCD/DLP projectors will play the signal properly. I wish to know how macrovision is compensated - unless what I believe is not true.
Regards,*** My computer can beat me at chess, but is no match when it comes to kick-boxing. *** -
ok,but i asked him about his problem,and he has told me that on certain colors and especially the black,he had ,what he describes as a pulsing onscreen,be it RGB,or S video.
so he got a stabliser,and alls well.he didnt want to chip his dvd player,and there were no macrovision hacks for it either.
his two projectors were a sony crt one,older model,and a new lcd one,very small,and for the life of me i cant remember the brand,maybe sony too.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
I use component hooked directly from DVD->DLP projector.
I also have composite hooked DVD->Receiver->DLP Projector, and Macrovision is non-existant even through SVideo from Receiver->DLP Projector(Receiver up/downconverts video signals)
I doubt you'll have a problem,
Cheers -
There are various forms of Macrovision but the VHS type will not affect monitors. It's designed to confuse VCR servos and AGC circuits but monitors can usually handle it.
OK. Here is a reply I received from Infocus:
Thanks to the on board state-of-the-art Faroudja deinterlacer, the 4805 DLP projector is fully compatible with Macrovision protected video signals, so you will not have any Macrovision effects*** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
Comparing LCD and LED projectors: apples and oranges?
By Haopengyou in forum Media Center PC / MediaCentersReplies: 3Last Post: 24th Feb 2011, 18:59 -
nano projectors?
By Haopengyou in forum Media Center PC / MediaCentersReplies: 1Last Post: 6th May 2010, 08:07 -
HDTV Technologies - LED, LCD, Plasma and DLP.
By prankstare in forum DVB / IPTVReplies: 0Last Post: 13th Aug 2009, 00:50 -
Who Likes Projectors?
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 10th Jan 2008, 17:35 -
WHAT TV SHOULD I BUY? LCD vs. PLASMA vs. DLP TVs...
By jimmayor007 in forum Newbie / General discussionsReplies: 3Last Post: 1st Sep 2007, 17:09
