Anybody know an easy way to repair my MPEG? I get the following from MPEGVALIDATOR:
MPEG-2 Validator v1.4.0.131 - 4/3/2005 8:44:39 PM
File under analysis: "F:\03-13-2005-1900[WUHF-DT].mpg"..!
Begin Process:
Begin Program Streams Summary:
Missing Progam End Code...
File "F:\03-13-2005-1900[WUHF-DT].mpg" is a MPEG-2 Program Stream
MPEG file size 1893.58 MB
MPEG Packs = 404890
Sectors delay = 114.3 ms
*System headers = 0
*MPEG Pack Size = 8225
Packets per Pack = 1
*Program Mux Rate = 5025 Kbps, Min. Recommended = 14391 Kbps
*PTS underflow (Mux Error)...!!
Total PES packets = 404890
PES Packet Lenght Max. = 8205
Number of Video Streams: 1
*Number of Audio Streams: 0
Private Stream 1, ID: BD, packets = 126748, Total = 95061 KB
Video stream, ID: E0
PES packets = 278142,
Total = 1790.91 MB
End Program Streams Summary.
Begin Video Streams Summary:
Elementary Stream E0 is a MPEG-2 Video Stream
Video Delay Stream E0 = 650.0 ms
Number of Frames = 417 -> 6.95 Sec
Number of Sequence Headers = 29
Sequence Headers Aligned = Yes
*Horizontal Size = 1280
*Vertical Size = 720
*Aspect Ratio = 16:9
*Frame Rate = Invalid
*VBV Buffer Size = 488 -> (976 KB)
*Stream Type = Invalid
Chroma Format = 4:2:0
Picture Structure = Frame
Intra DC Precision = 10
*Top Field First = No
*DCT Type = Frame
Quant. Scale = Linear
Scan Type = Alternate
Frame Type = Interlaced
Number of GOPs = 29
*First GOP Closed = No
Number of Closed GOP = 0
Max. frames per GOP (without first & last) = 60
Min. frames per GOP (without first & last) = 60
Avg. frames per GOP (Total) = 14.38
Max. Frame Size = 106278
Min. Frame Size = 13334
Average Frame Size = 30521
Frames I = 29 -> 6%
Avg. Frame I Size = 428 KB
Frames I Total Size = 2345293 bytes, size 18%
Frames P = 110 -> 26%
Avg. Frame P Size = 112 KB
Frames P Total Size = 5195650 bytes, size 40%
Frames B = 278 -> 66%
Avg. Frame B Size = 44 KB
Frames B Total Size = 5186326 bytes, size 40%
Nominal bitrate (Sequence Header) = 19000000 bps -> 18554 Kbps
*Average Bitrate = 14292 Kbps
*Peak Bitrate (1 sec) = 14549 Kbps
End Video Streams Summary.
Begin Audio Streams Summary:
End Audio Streams Summary.
Video Stream Duration: 6.95 sec -> 6:57 (secs:frames)
Duration Difference from Video to Audio = 6950 msec
Initial Delay Audio to Video (PTS based) = -650 msec
Processing time: 12:00:38 AM
Result:
Compliance Test: Fail!!
End.
Need info on field order for capturing mpeg video
By snafubaby in forum Capturing and VCRReplies: 3Last Post: 22nd Dec 2010, 07:58 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 05:07 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
firewire info
By psxiso in forum Capturing and VCRReplies: 5Last Post: 15th Jul 2007, 06:08 -
HD DVD info
By skaterboii in forum Newbie / General discussionsReplies: 3Last Post: 27th May 2007, 04:43
