  1. Member neo*2's Avatar
    Mar 2002
    canada
    Hi, I've had bad luck with software coflicts when it comes to antivirus and spyware protection software. Can anyone recommend spyware protection that won't conflict, I want to run a new browser like Firefox as it claims to have great protection for spyware but worry if this was a problem the last time I had it installed?
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    firefox has a new version out 1.02 try downloading it. i use ad-aware spyware software the freebie one with no problems at all. i have bloated ware nortons antivirus and freebie avg antivirus on all my pcs with no problems at all with DVD DECRYPTER & DVD SHRINK.
    USA
    I use the free AVG antivirus, along with SpyBot S&D, and SpywareBlaster. None of them seem to interfere with each other or other programs.
    I don't use Firefox, but I understand it has less vulnerabilities than IE6 as far as Trojans and viruses, so it's probably a good choice.
  4. my system:
    Firefox v1.02
    AVG antivrus free version
    Webroot Spy Sweeper
    Microsoft Antispyware-Beta free download ( I like this one )
    Ad-Aware SE Professional
    spywareGuard
    spywareBlaster
    no conflects here.
    I use DVDRebuilder / CCE
    DVDShrink
    DVDdecrypter
    NEC ND3500A/G
    Unproper and proud of it
  5. "the last time you had Firefox installed"
    What version? I still run 0.9 and no conflicts. Along with Spybot, Sypwareblaster, Zonealarm and now AVAST Free antivirus since the new AVG screwed up everyone's computer I know that tried to update to the free 7.0 vs.
    (I know I should update Firefox but there are a couple extensions I really like that have not been updated to work with versions above 0.9.)
    If you have conflicts with any of the above I would think some system function is corrupt...
