i'm on the warpath to completing a project, this project consists of converting about 60 vhs to dvd .... i have an ati tv wonder pro, and it works like a charm, i have it set up perfect and can caputre good audio/video -- the problem is is that after i capture the video and "finish - save to computer" in dvi format --- i just lose the audio...my friend told me that this happened to him to -- is this a known error? (could i just be missing a codec to play the mpeg2 audio?) anyway --- if someone has converted a bunch of vhs to dvds and know of a good capture - edit - finish/burn program or diff programs for each step (thats efficient -- i have 60 to do), i'd greatly appriciate it....i have toyed arround with sonic my dvd --- and thinks its kinda crazy (especially for capturing) and have used inter video a little. Any help/suggest/profanities/belittling would be greatly appriciated. Thanks, really thanks you![]()
Try and capture directly to mpeg-2.
Author directly to dvdr.
No more codec issues, no more lost audio...Cheers, Jim
My DVDLab Guides -
how would i capture directly to mpeg 2? (is it possible with windows movie maker? and author directly to dvdr with sonic my dvd or what? thanks
=milk= -
No, not with WMM. Take a look through this list: https://www.videohelp.com/tools?toolsearch=&s=5&orderby=Name&hits=50&convert=&dvdauthor...+or+List+tools
Find one that caps to mpeg-2.
Author with Sonic if you must. Look under HOW TO AUTHOR for far more options.Cheers, Jim
My DVDLab Guides
Best software to edit and burn mpeg video on PC?
By daysaf00 in forum Authoring (DVD)Replies: 3Last Post: 29th Jan 2012, 02:02 -
Need help to copy,edit and burn movies from my camcorder
By timlab1955 in forum Newbie / General discussionsReplies: 13Last Post: 25th Nov 2010, 20:48 -
convert HD to SD for edit +burn
By Ellie3 in forum Newbie / General discussionsReplies: 0Last Post: 14th Nov 2010, 23:13 -
Magix movie edit pro 15 burn problems
By wolfspirit1964 in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 17:10 -
Help with DL DVD burn no playability :edit fixed
By WBFAir in forum Authoring (DVD)Replies: 19Last Post: 25th Jul 2008, 02:25
