  1. does anyone know how to beep out or mute word/s from a video file?
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Demux audio and video (tmpgenc, virtualdub, etc) use ^ to beep/mute out naughty words, then remux (if you have to). Many authoring programs will take seperate streams for input.
  3. Member AlecWest's Avatar
    Mar 2002
    Vader, WA, USA
    Originally Posted by reboot
    Good advice. If he's looking for something cheap, though, he could always search for Goldwave's predecessor - Multiquence. V1.02 was uncrippled shareware that only had a brief nag-screen ... but, afterward, was fully-functional. It's tough software to find, though.
    If you do find Multiquence V1.02, all you have to do is demux the video file, convert the audio file (AC3, MP2, ?) into a stereo WAV file, then use the volume controls to "blank-out" the objectionable part ... saving the file, and reconverting it back to AC3/MP2/? and re-muxing it back to the video.
  4. Convert to WAV then use Audacity->Silence Selection.
  5. Good point. Audacity is free.
    Cheers, Jim
    My DVDLab Guides
