When I use Easy CD creator 5 to burn 689MB - 699Mb data to 700Mb blank, I got no error, but after 'burn sucessfully'.
I can't read the data at all.
Anyone knows why ?
jokarmo,
THere's many reason for you not to see your data. Could you detail your process of making your vcd? Jordan -
I'm not burning VCD,
I'm burning DATA
using Easy CD Creator 5 Wizard
whenever I burn <680Mb its fine, but above 680Mb the problem start.
btw I use HP CDwriterPlus 8100, and Fuji 700Mb Media
Let me know what more details do you want, I'm very curious to solve the problem.
and I also like to know if others has the same problem too. -
A friend of mine has the same burner and he once said that 80 min CDRs are not fully supportd with this burner, he could only burn max 78 min music CDs ... So your problem is an old, crappy burner
Have a look here for a bit of explanation http://www.hp.com/cposupport/information_storage/support_doc/lpg40817.html
One thing that stands out is your comment about the wizard and this extract from the link above:
" Easy CD Creator 3.01d and later will allow recording data or audio on an 80-minute disc, but it is NOT supported through the Wizard. Use the main interface instead."
Sounds like this may be your problem. -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
hmmm, that might explain it
Burning Data at 4x
By rickoshay in forum ComputerReplies: 9Last Post: 19th Feb 2010, 14:05 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
DVD Data Burning Query
By gilera in forum Newbie / General discussionsReplies: 17Last Post: 4th Feb 2009, 04:32 -
Burning data-dvd
By btkuehn in forum Authoring (DVD)Replies: 37Last Post: 9th Oct 2008, 19:55 -
Need help burning a 700mb file onto a disc to be played on DVD player
By chaoscreater in forum Video ConversionReplies: 7Last Post: 11th Jul 2008, 04:20
