I did have a disc in - I tried two just to be sure...I guess it doesn't support my burner....however, I did do the "scan disc" which is where I got my image from.
Results 31 to 38 of 38
you may want to check the firmware on your dvd burner. there may be a newer firmware for your drive. it's odd that your burner isn't supported with cd/dvd speed.
if there isn't a newer firmware for your drive then it could be your dvd burner or the media is fake. does the TY have a serial number embedded into the hub of the disc? anyone else you know that can burn that TY discs for you in another dvd burner? -
well it's about time you showed up steve!
any ideas for him? i'm fresh out of suggestions.
The disc has read errors as shown,doing a transfer rate scan will show massive dips with nero cd speed.Best to reburn the original files if possible.
yeah, there's a number on the hubs of the dvd's....
is it strange that I have NO playback problems at all? but my friend does? that leads me to believe it's her dvd player - but then when I look at the scans.....I think differently.
i'm gonna go for tonight, but i'll be back tomorrow for more trial/error
thanks for the help!!!!
goodnight. -
Possibly discs with a fake TY media code. Link us to the discs you bought, dvdguy. If they were their 'supermedia' branded discs they're fake. If they're being SOLD as TY discs under the Taiyo Yuden brand there's roughly zero chance of them being fake. Having rough edges is not of any indication of quality, or lack of it. Most of the best media I've used has rough edges, RICOHJPNR01 for example has rough edges. On the other hand some of the worst media I've used had smooth edges.
P.S. - doing a transfer rate will do as johns0 says, actually it'd likely fail to finish because of an eventual read error. -
so basically there's no way of knowing whether or not I have fakes - i'm making a completely new movie now, burning to -RW first - will scan that disc for errors - if it's ok, i'll try a new TY.
Taiyo Yuden DVD-R's (In Australia)
By SE14man in forum Newbie / General discussionsReplies: 0Last Post: 20th Jun 2011, 04:21 -
JVC Taiyo Yuden Blu-ray White Inkjet Printable 4X 25GB BD-R LTH
By xobituaryx in forum MediaReplies: 2Last Post: 17th Jan 2011, 10:25 -
Taiyo Yuden DVD -- are these shiny?
By lordsmurf in forum MediaReplies: 10Last Post: 21st Jan 2009, 14:45 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 11:29 -
Taiyo Yuden DVD-R - Thanks
By casual-dvduser in forum MediaReplies: 3Last Post: 6th Jun 2007, 03:59
