im using a mpeg i downloaded for as part of a documentary for school, but the quality isnt great when viewed in full screen.
ive converted to avi via virtual dub so i can edit it in premier.
is there anyway to improve the quality of the mpeg and hide the damage caused by the compression?
Nope,Cant replace whats not there,you can try a De-block filter or maybe a bit of blur,but really No.
is there not a program that can add new colors to the mpeg based on those around it so it looks less smudged?
How does the mpeg compare to the avi? What type of avi did you choose? ie what compression type, resolution etc.? If the avi is not as good as the mpeg then your conversion process needs to be adjusted. Vdub has filters available so that you can adjust colour, sharpness and noise etc. These would be applied when you convert from mpeg to avi.Originally Posted by watermelon"Art is making something out of nothing and selling it." - Frank Zappa
the avi was done with no compression and is exactly the same as the mpeg.
i was wondeirtng if there was a way to improove the avi footage, to mask the mpeg compression somwhat. -
Try 2d cleaner for virtualdub filter.
Need help improving the quality of this anime
By Luminous69 in forum RestorationReplies: 11Last Post: 17th Jun 2011, 19:00 -
Improving quality?
By BwanaP in forum Video ConversionReplies: 30Last Post: 19th Jan 2010, 22:03 -
Improving video quality
By rusting in forum Newbie / General discussionsReplies: 10Last Post: 10th Jun 2009, 00:35 -
Improving Video Quality
By pctech@apc4me.net in forum Newbie / General discussionsReplies: 2Last Post: 30th Mar 2009, 18:39 -
Improving quality of mpeg before converting to dvd...
By AshleyQuick in forum Newbie / General discussionsReplies: 4Last Post: 28th Apr 2008, 14:41
