Results 1 to 9 of 9
  1. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    hello everyone, i am recently experiencing this problem with my comp and frankly, its ticking me off. what happens is that on my comp, i finish with wat i need to do on my username, and i SWITCH USERS (not LOG OFF). so the main screen of XP shows up. then someone else uses the comp in their username and again switches users to the main screen. when i go back on the comp, i find out my taskbar is missing! i try everything and finally with no choice, i have to log off and back onto my name, its not much of a problem but as i mentioned, its really bothersome. can anyone give advice of what to do about this? thanks alot...
    P.S. my taskbar is set to autohide, if it makes any difference...
    Wow! You got shocks, pegs... LUCKY!
  2. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    If your taskbar is set to autohide, then it will be hidden until you hover over it. Uncheck the autohide under taskbar properties.
  3. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    i know, i do hover over it but it still doesnt show.
  4. Member jackal70058's Avatar
    Jul 2004
    Louisiana
    Maybe you could try turing AutoHide off and see if it solve you problem.
    I remember having a taskbar issue in Windows NT and turning Auto Hide off fixed problems.
  5. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok i think ill do that thanks
    Jul 2001
    skip2mylou,
    That's a good trick to play on unsuspecting people. Ever click and drag on the edge of your task bar and make it two or threes lines bigger?
    Well, you can actually bring it to the bottom and make it ZERO lines.... Simply bring your cursor to the bottom of the window until you see an UP/DOWN slider pointer and drag it up one or two notches.
    What you should do to prevent (accidentaly) doing this is right click on it and LOCK the taskbar, once its the way you like.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  7. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    thanks ill keep that in mind as well u never know when youll need these little hints...
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Don't use switch user. I can cause instability and uses resources needlessly. I disable it on every install I do, along with hibernation. M$ should have left these 'features' off the final list.
    Read my blog here.
  9. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    o ok
    but i found that when my screen saver comes up, and when i exit it, the taskabr is back up, so i set the screen saver to like 2 mins, so thanks to u guys, i have found a way around this problem, thanks...
