Hi,
Using DVD2AVI, how do you just get the sound only (wav)?
Thanks!
Is there a problem ignoring the tiny pointer file DVD2Avi creates? Come on, people ... don't try to create a problem where there is none.
Not much of an answer there Anty, guess you're just trying to be a smart a$$. ..Aah, it worked.
don't want the tiny pointer file. If you select Save AVI, you get an AVI and a WAV, there's suposed to be a way to just get the WAV, if somebody can tell me how, I'd appreciate it. -
Dude Antny is right...just ignore/erase the d2v file, whats the big deal, it wont be any faster, all the speed is in creating the wav file, not the d2v file...you are seriously making a mountain out of an ant hill.
What did Antny say that was right? I don't understand what you are talking about. How is ignoring/erase the d2v file going to make a WAV? Please explain.
Hi Up!
If you open the vob file and then just select save project, you will get a d2v ( really small file) and a .wav file.
Regards,
Jose Febus -
<font size=-1>[ This Message was edited by: UpChuck on 2001-12-12 06:07:40 ]</font>
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
