I am looking to buy a AV capture device for use with my laptop. (3 GHz P4 HT, 1 GB RAM, 128 MB Radeon 9600 Pro) Ones I have tried in the past have been pretty crappy. I basically want something that will allow me to capture video at the best possible quality and also be something I can use to hook up video games systems and play them on my laptop's LCD. I have 3 USB 2.0 ports in case that is a factor.
Looking forward to some input. Thanks.
Would buying this:
http://www.adaptec.com/worldwide/support/techspecs.jsp?prodkey=AFW-1430&cat=%2fProduct...&fromarea=prod
and then getting a firewire-based capture device be a good idea? -
First of all, any AV capture should not be usb, lots of trouble in most cases there. If you don't have a firewire port, it may be possible to get one on a card, I don't do much with laptops so I don't know. With a firewire port you can use some video cameras to directly capture video. I suggest windv as a transfer program, it's good and free. The other best solution, with no video camera is the Canopus ADVC 100 box, which takes input video and converts it to DV, which is then fed to the firewire port in your computer. Search in capture card section for reviews, all I will say about it is that it simply works and does just what it is advertised to do, every time. You will seldom find anything negative said about it by people who actually own and use one, the negative comments usually come from people pushing another product. One drawback to any video work on a laptop is that the files tend to be very large. DV video is about 13gig per hour, with additional room needed for the DV to mpgII conversion, to make compatable dvd files. You might need an external hard drive.
I don't do the games thing, can't help you there. Nyah Levi
An LCD TV without 75 ohm coax input install where only a coax input can be
By dss4u in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 13:09 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 12:46 -
Guidance on new pc purchase
By hygieneboy in forum ComputerReplies: 12Last Post: 29th Jan 2009, 22:54 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59 -
One input record other input?
By Davron in forum Capturing and VCRReplies: 1Last Post: 30th Jan 2008, 18:20
