  1. If I want to take a movie off my computer and stick it on a CD(s) to play in my DVD player what format should I use to get the best possible quality? Should I make a VCD, SVCD, XVCD, or XSVCD? Would the XSVCD be the best for quality picture and sound? Size doesn't really matter for me.
    Mike
  2. if size doesnt matter go with either svcd of xsvcd... i have never played around with xsvcd so i cant comment on that... but if size doesnt matter svcd with the bitrate jacked up would work great for quality.
  3. So say I have a divx movie that is 677 mb. I make a SVCD with a bitrate of 384, which is the highest possible for SVCD. Do you know about a how big this would be? Would it fit onto 2 CDs?
    thanks
    Mike
  4. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    thanks
    Mike
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Getting a little confused there, that might be the highest audio No good asking us if the movie will fit without the length of it either. Go to the tools section on the ;eft and look at the bitrate calc. That well answer your question.
