The link for this program "cinematize" is http://www.miraizon.com/products/products.html, (this is not warez, it is a legit program)
anyway, it's called an extraction tool. IT's description is as:
"ideo and audio editing used to be a one-way street -- make your creation and then burn it to a DVD. Sure, you could duplicate the entire DVD using copy tools, but there was no easy way to extract scenes back into an editable format while preserving the high quality of the original.
Miraizon Cinematize turns this "impossible and difficult" experience into a "fun and easy" one."
but it seems like the pgram is nothing more than a combination of dvd2avi + virtual dub. Am I wrong in this or is cinematize really a different program entirely?
i haven't tried it... i refuse to install quicktime(it is required)...
but does it just include dvd2avi and virtualdub with a gui? -
I'm not sure, I haven't even tried the program out. But based on the description it sounds like this new program functions like dvd2avi + virtualdub.
I'm just trying to confirm if this is true or not
What is this called and how do I fix it?
By jarlaxle in forum Newbie / General discussionsReplies: 5Last Post: 28th Feb 2012, 03:08 -
What shot is this called?
By Chippy in forum Newbie / General discussionsReplies: 4Last Post: 17th Apr 2009, 23:47 -
"Isn't that why you called?"
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Apr 2009, 18:38 -
Effect? i dont know what it's called
By upper in forum Newbie / General discussionsReplies: 14Last Post: 15th Mar 2009, 02:33 -
Cinematize synch problems
By whoisquilty in forum MacReplies: 4Last Post: 5th May 2008, 18:34
