Can anyone give me suggestions, links or guides on converting video files to an acceptable avi format for this Archos 480? I have been trying numerous convertors and nothing has yet been a recongnizable avi format. Any help would be greatly appraciated
Thanks in advance
Virtualdub is the only one Archos has validated to make files that are in snyc (audio/video). Programs like Dr DIVx do not work on the archos unit. I have the AV400 and the snyc issues have not been corrected with firmware, in other words their idea of MPEG 4 is not the known or accepted standard.
This is how I do it. I rip a DVD to a single VOB file then use Dr. DivX to convert to Mpeg4 avi. Then I use the Archos converter software to convert to the Archos standard. Works fine for me. Now if I have and Mpeg2 file I have to convert it to Mpeg then I can use the Archos to convert to the Archos standard. I use Sony Video Studio to convert to Mpeg.
Y-ASK -
2 questions. What are the Archos standards ? Where can I locate the Archos converter software ?Then I use the Archos converter software to convert to the Archos standard.
THANKS FOR YOUR HELP SO FAR!!!!!! -
Archos uses divx or xvid formats. I have used AVS Video Converter successfully with an Archos 340. The software is easy to use and has worked very well.
Look here: https://www.videohelp.com/tools?tool=AVS_VideoConverter
[Archos 605] transform from 720p.HD.DVDRip.XviD.AC3 to Archos format ?
By birdwing in forum Portable VideoReplies: 2Last Post: 5th Nov 2009, 23:41 -
Archos and shrink.
By Square eyes in forum Portable VideoReplies: 4Last Post: 1st Aug 2008, 16:43 -
help with my archos 605
By mustang1967 in forum Video ConversionReplies: 4Last Post: 27th May 2008, 21:43 -
avi (640*480) to dvd (720*480) without black bars....how?
By Mauserman in forum ffmpegX general discussionReplies: 8Last Post: 10th Sep 2007, 12:25 -
Archos 404 & DVR stand vs Archos AV 500 - difference in MPEG-4 recordin
By DavidMcGowan in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2007, 05:49
