Ok, So I took my AVI file and coverted it.. Just left it on overnight and in the morning I took it out and put it in my DVD player.. It boots up but all I see is a directory with the Video and Audio TS folders.. Thats never happened before and for some reason my DVD player wont play it.. Usually when I encode and burn using DIKO it just starts the movie right away.. How can I fix the problem so just the movie starts?
AVI Specs:
Codec: DivX (Was Xvid but 4cc it after the DVD didnt work)
Video Bitrate: 757 kb/s
FPS:23.97
Audio: 0x0055(MP3) ID'd as MPEG-1 Layer 3
Audio Bitrate: 119 kb/s (59/ch, stereo) VBR LAME3.93a
FS:48000 Hz
Resolution: 576x304 (1.89:1) [=36:19]
Can anyone help?
can you play it with your software dvd player(not the autoplay)?
check the video_ts folder, do you see any files? -
Yea, there are files in the Video TS folder.. But when I try my DVD player (not software, dont have software) it comes up as a directory but it never did that before.. All I want is for the movie to just autoplay..
Encoding with diko
By djgazzabhoy in forum Authoring (DVD)Replies: 2Last Post: 13th Dec 2010, 05:49 -
Question about DIKO
By Belfour in forum Authoring (DVD)Replies: 7Last Post: 6th Aug 2008, 01:27 -
Error using diko
By thecrock in forum Video ConversionReplies: 4Last Post: 24th Apr 2008, 17:55 -
How to make DIKO files into DVDFiles ?
By Locutus666 in forum Authoring (DVD)Replies: 17Last Post: 4th Nov 2007, 04:31 -
DIKO for dvd burning
By wristar in forum Authoring (DVD)Replies: 1Last Post: 29th Oct 2007, 14:41
