System: Home Built AMD Athlon XP 2400 on ECS K7YTA3 with latest v80E bios. 512MB memory and three HDD (120GB, 80GB & 20GB).
The Emprex was running the A07M firmware. Anytime I put in a blank CDR or a DVD-R, Nero Infotool shows that it will only write at half the speed capable of the drive. Such as, it will write a CDR at 48x, but Nero 6 and Roxio 6 both say it will only write at 24x... Nero Infotool shows this also. When I put a TDK or GC blank 8x DVD-R in the drive, although the drive will burn up to 16x both Nero 6 and Roxio 6 both say it will only burn at 4x, half the disc speed.
I downloaded the latest A07R firmware and it didn't make any change, it still would only burn at half speed. I returned the drive and got another one in case there was a problem with the first one, but the second one has the same issue.
Anyone have any ideas?
Check to make sure DMA is enabled for the drive.
I have a BTC DRW1016IM and it burns at the correct rated speed. I would say the problem is in your setup. -
Interesting fact is, I can put the old Pinnicle I had back in and it burns a CDR at 42x.
Firmware
Audio is half the speed to video
By pixaren in forum Capturing and VCRReplies: 1Last Post: 2nd Nov 2010, 07:40 -
All video playing half speed?!
By MJ Peg in forum Software PlayingReplies: 8Last Post: 2nd Mar 2010, 12:07 -
Problem, videos playing in half speed.
By jgib7687 in forum Newbie / General discussionsReplies: 4Last Post: 26th May 2009, 11:17 -
:?: half-speed play with no audio pitch change?
By gregconquest in forum Software PlayingReplies: 8Last Post: 10th May 2008, 23:21 -
when WAN is connected to the router the network speed drops to half...?
By stars in forum ComputerReplies: 18Last Post: 19th Feb 2008, 12:44
